90 4Runner standard w/3VZE climate power control issue
Hello all!
I have some electrical gremlins in this runner I picked up and rebuilt the engine, and wanted to run past you all.
1. The climate controls do not work at all.
2. the radio doesn’t power up.
3. The fuel relay? under the drivers dash was found disconnected, when I connect it, I get no engine start. Disconnected it starts. Also the cold start injector isn’t getting power, could that be related? I metered the cold start switch, and relay and they are within limits.
I’m thinking there has to be a bad ground somewhere for the climate and radio to not work. I have voltage to the blower, all fuses have power.
besides the three grounds in the engine compartment, is there a ground to the body in the cab?
thanks for looking at this post!
The kid that had this previously had done some bypasses, one with the throttle body connector that was disconnected and resistors out , and the EGR/Pair delete.
rmeyers413
11-26-2013 11:11 AM
crankyster_01
04-16-2013 03:45 PM
2clean
10-29-2012 08:43 PM
