90 4runner needs your help
HI I HAVE A 90 TOYOTA 4 RUNNER THAT I PULL BEHIND MY TRUCK WITH A TOW BAR, AND IT WAS WORKING FINE FOR A FEW TRIPS BUT ONE DAY I WENT TO UNHOOK IT AND THE DARN THING WOULD NOT MOVE IN ANY GEAR BUT AS SOON AS I PUT IT IN 4LOW IT WORK JUST FINE AND 4HI AND 2HI IT WILL NOT MOVE COULD YOU GIVE ME SOME ADVICE ON WHAT IT COULD BE OR WHAT TO CHECK. THANKS A MILLION
Id consider offering advice if you didn't type your whole speal in caps and centered. If you cant type on your computer, mabey you should leave the toyota for a profesional.
Yep, that's the problem.
Not removing the rear drive shaft has now purchased you a new transmission. It's in the owner's manual how to tow it with the rear tires on the ground.
Why can't the automatic be towed in neutral? What happens mechanically that causes damage?
Let me get this straight, to flat tow an automatic, you need to pull the DS? I'm assuming the 5spd is fine towed in neutral.
Because none of the moving parts in an automatic receive lubrication without the torque converter pumping the fluid through. Since you're in neutral, you're not spinning the torque converter.
x3 - with a manual transmission (which is essentially what the transfer case is), the gears sling the oil as they rotate, so if any gear is spinning its getting lubricated ...
Flying91
45
04-11-2024 04:39 PM
BeMiceElf
10-10-2015 09:40 PM
