**89silverpu's e-locker retrofit build**
Old 01-26-2010, 09:27 PM
  #61
874runnersr5's Avatar
4.10 and 4.56. Not sure what one im going to keep. Ive got + and - right. If i sell the 4.56's i can plop the 4.10s and ya. Or i can try to find some 4.56 ifs front. either or ill be happy but i kinda want to lean towards the 4.56s so i can regear and have a elocker.
Yeah, im planning on selling one or the other.
Old 01-26-2010, 09:30 PM
  #62
SpecialScottie's Avatar
Did you make a breather for the locker motor? When I installed mine I noticed the little tube coming out of the locker and was wondering if I should extend it
Old 01-26-2010, 09:44 PM
  #63
i was taking a look at mine to tonight, i dont think it would be hard work to perhaps put a t fitting into my diff breather line... perhaps thatll work
Old 01-26-2010, 09:46 PM
  #64
Thats what I was thinking. Is that tube indeed a breather?
Old 01-26-2010, 09:48 PM
  #65
89silverpu's Avatar
Yeah I made a breather, kinda random, but I had a messed up brake line laying around so I just cut about a 1 inch piece of that and jammed it in one end and bought some hose and jammed the hose on to the other end...been holding up just fine and I've been through quite a bit of water with it.
Old 01-26-2010, 09:51 PM
  #66
89silverpu's Avatar
Yeah you should for sure keep the 4.56's, you'll be kicking yourself if you don't when you find a deal on some front 4.56's...you can find a front diff with those gears for around 200 bucks...
  #67
A hard line or a rubber one?
Old 01-26-2010, 10:01 PM
  #68
89silverpu's Avatar
Hard, it was a tight squeeze, but that way it'll stay.
Old 01-26-2010, 10:04 PM
  #69
Yeah no doubt, if not cheaper..
well im not sure if i want to tackle rebuilding this diff or let it to a pro..
oh well, main thing is i finnaly have one.. haha
Old 01-27-2010, 12:18 PM
  #70
did elockers ever come in 3.73s?
Old 02-03-2011, 08:45 PM
  #71
BigBluePile's Avatar
Getting ready to modify my axle housing and install my elocker!
Old 02-03-2011, 08:59 PM
  #72
scuba's Avatar
05+ V6 Tacomas all had a 3.73 ratio. And a lot of those are elockers.
Manual FJ's had 3.73's as well. The auto FJ's have 3.90's
Old 02-03-2011, 09:01 PM
  #73
Birdbrain's Avatar
scuub
Old 06-26-2011, 08:58 PM
  #74
ToyoTech559's Avatar
i know this is old but i plan on doing this really soon. i just picked up a 4.30 elocker from a 2000 4runner. im gonna regear to 4.88. i have an extra axle housing im gonna do the mod to.
i have a 88 4runner v6 auto with a few questions.
do i need different axle shaft or will they plug into the elocker?
will the elocker pinion flange bolt up to my drive shaft?
Old 06-26-2011, 09:27 PM
  #75
paynemw's Avatar
bump... I've got a TRD e-locker sitting in the garage WAITING for install...
Old 06-26-2011, 09:34 PM
  #76
No and yes....
Old 06-26-2011, 09:37 PM
  #77
No and yes....
thanks. now should i order a regular v6 488 RP set or a Elocker 488 RP set? reason i ask is i read that the pinion flange is different
Old 06-26-2011, 10:17 PM
  #78
one last thing.
i have G292 which is confusing because i have checked and i do have a v6 diff. but according to the axle code its only 2 pinon? there for my axle shafts wont work with the elocker?
If you have the axle code of your vehicle, it is easy to find out what size differential, what ratio, and what pinion set-up you have. This will also help if you are hunting for a particular unit off another vehicle. The axle code is in the vehicle ID plate under the hood or drivers door. The axle code is 4 digits: a letter followed by 3 numbers.
Example: G292 = 8.0" 4.10 final ratio 2 pinion
Code:
1ST R&P SIZE 2nd/3rd R&P RATIO 4th DIGIT PINION SET-UP
F = 7.5" 07 = 3.900 2 = 2 pinion
G = 8.0" 08 = 4.110 3 = 2 pinion LSD
10 = 4.375 4 = 4 pinion
14 = 4.875 5 = 4 pinion LSD
25 = 4.556
28 = 4.300
29 = 4.100
Old 06-27-2011, 06:29 AM
  #79
dntsdad's Avatar
Originally Posted by Junkers88
Man that looks great!!! CONGRATS!!!!!!
I want to do this when I regear to 4.88's front and rear but finding an E-locker for less than 800$ is almost impossible out here.
I have bought 2 Elockers in the past couple months. One for $150 and one for $250. Both appear in excellent condition and were takeouts of totaled Tacomas.
There are deals out there if you look often and are patient. I walked away from a LOT of people until I found good deals since I was not in a hurry.
Also, remember you do NOT have to find a deal "out here". UPS goes everywhere!!! I am in California and bought my last one from a guy in Ga. UPS is about $50 to ship a bucket with a 3rd in it across the country. Cheaper if you know someone with a business and a UPS account and you can set up shipping to ANY business address.
justdifferentials
Just Differentials
06-13-2022 07:40 PM
1uzRunner
63
11-10-2018 03:58 PM
clok
11-19-2015 01:09 PM
Patrick1976
09-15-2015 11:33 PM
zz_denis
09-06-2015 03:43 PM
Quick Reply: **89silverpu's e-locker retrofit build**
