89 pickup radiator, is the 2wd the same as 4wd?
Ok, found out the radiator is shot in the truck I am putting together (picked up the radiator and the core fell out):pat: . Is the 2wd radiator the same as the 4wd radiator? I noticed they are all over ebay, but only for 2wd. I just want to make sure the 2wd will work in my 4wd yota.
i recently put in a radiator that came out of a auto 2wheel drive 1 ton yoda in my 87 4runner 5 speed 4x4 it only had 2 rows for the coolant instead of 3 and was just a bit shorter. it bolted up and worked fine but i had to cut my fan shroud a little to get it to fit perfect. and i haven't had any issues of over heating i actually think it runs a little cooler now
Avenged
07-09-2015 07:55 AM
