89 4Runner Power Window Master Switch Disassembly
In my prior post regarding my drivers side power window issues, https://www.yotatech.com/forums/f116...inding-309459/ I ended up swapping the motor but it seemed there was still an issue with the switch when raising the window. I decided to try and dissemble the switch and try to clean contacts and determine if anything was loose or broken. I'm almost there, however I'm stuck with trying to remove the Windows lockout button. I was able to remove the cover but there is still a square head that will not fit through the opening.
For anyone out there who has done this, how do you remove the lockout switch? Here are a few pics of what I've been able to do so far.
Thanks.
Thanks.
ElwayLite
11
12-17-2005 09:07 AM
