89 4 runner auto trans troubles
Ok, so I bought this 4 runner knowing it had transmission problems. the truck runs fine, starts right up, and runs good.
When you shift the truck into anything drive, reverse, 1,2 whatever it does nothing, no change in engine speed, no funny noises nothing.
I made sure that all the linkages and wires where hooked up correctly, everything seems to be fine, but I have no movement whatsoever.
My original thought was that the guy I bought it from didn't install the torque convertor, but I separated the engine and transmission today and there was a convertor.
I have another convertor and transmission to swap in but I really don't want to if I don't have to.
Thanks for listening to my tale of woe, any ideas or things for me to check?
90 runner 22re with an auto
Well, two things. If the converter wasn't filled with a couple quarts it could have been damaged if put in gear before the front pump filled it. The other is if there's no fluid even after running the engine then the front pump is afu.
The truck doesn't even try to move. The engine doesn't bog down you can Rev it up and still nothing. High range low range it feels like there is no connection between the engine and transmission. I know I probably just need to go ahead and swap out the transmission, I was just hoping that somebody with more Toyota specific experience might have some Insight
06-01-2021 01:51 PM
MMA_Alex
25
04-18-2017 05:07 AM
Jnkml
07-06-2015 01:20 PM
