89 22re cam chain question
Well I am putting the motor back together after a head gasket replacement and I am wondering how the cam sprocket goes back on the cam with the chain being so tight? I am pretty sure the tensioner has fully extended and I need to know how to retract it so that I can bolt on the sprocket. thanks
You can either pull the timing cover and compress the tensioner....
I made the mistake and didn't put the bolt into the cam gear to hold it in place.
Using my LONG screw driver, I was able to push my tensioner over enough to put the gear back onto the cam shaft.
It is about 3/4 of the way down the front. Just above the oil pump on the passenger side.
09-04-2015 10:27 AM
