88 Toyota pickup - "pull and turn" brake handle
Old 07-04-2024, 05:16 PM
MichaelKLerner's Avatar
Is there any such thing as an aftermarket replacement for these handles? The oem is made of soft rubbery plastic. It's 30 yrs old and starting to dissolve. Grimed up with skin oils and dirt. It's like a spongy turd. I'd like to have something a bit nicer, like chrome, or a better grade of plastic. Got any ideas?
Old 07-04-2024, 07:51 PM
osv
osv's Avatar
that's a good question... i wonder if a handle could be fabbed up out of metal or wood, or 3d-printing.
i'd like to dump it entirely, in favor of a lift and button-lock on the tunnel, like my '97 miata has, and the old air-cooled vw's i used to own.
Old 07-04-2024, 08:42 PM
I am hoping someone has come up with a way to repurpose one of those hokey chrome pistol grip shifter handles that were popular in the 80s.
Custom Gunstock handle would also be cool.
3d printing is out of my league
Old 07-05-2024, 06:26 AM
YT Community Team
Jimkola's Avatar
I got one out of a wrecking yard that was in great shape, so I don't necessarily think they all fall part due to age. Getting a used one in good shape should be possible.
The following users liked this post:
old87yota (07-05-2024)
Old 07-05-2024, 09:33 AM
cashmoney00's Avatar
Originally Posted by MichaelKLerner;[url=tel:52496280
52496280[/url]]I am hoping someone has come up with a way to repurpose one of those hokey chrome pistol grip shifter handles that were popular in the 80s.
How do they attach? I can 3d print.
Old 07-19-2024, 04:47 PM
newschoolers's Avatar
the ˟˟˟˟ty part about them is they come fully assembled with the cables in them and then a pin pressed to never let them come apart in pieces, i have three or four of them in the shop they are just a cable and a stopper mounted in a solid rod inside a tube. the cable is attached to the rod with a stopper then fed thru the tube and a pin is pressed in so that they only rotate 90 degrees to indicated engaged or not basically
Old 07-20-2024, 08:38 PM
Giving up this one
When my oem shift knob became gummy and disgusting, I bought a nice one in faux leather and chrome. Same with the steering wheel. I love the change. Was hoping for something the same with the parking brake, but I can see that it would take a machinist to pull off.
I cleaned the handle. It's about as good as any used ones. And that's that.
Thanks for your patience and responses.
Old 07-21-2024, 01:32 AM
Melrose 4r's Avatar
How crazy do you want to get?
1963 and 64-66 Corvette used a similar pull and turn system.
Old 07-21-2024, 08:46 AM
That Corvette item is exactly what I would have been looking for but I am unclear on what it would take to adapt it to my truck. Apparently from what I am reading on this forum the toyota handle isn't meant to be replaceable. Am I right?
Old 07-21-2024, 08:54 AM
Melrose 4r's Avatar
Seems not like a Toyota thing to do!
But no doubt it would take some fabrication skills to adapt the vette handle.
Just remembered early Mustangs used a similar style…but Ford, yuck…
Old 07-21-2024, 09:06 AM
Can't prioritize this one. Have to let it go. But glad for the knowledge and feedback. Thank you
Old 07-21-2024, 01:09 PM
Discombobulated's Avatar
Good choice, I just changed my parking brake cable and it’s a pretty intricate assembly, too bad the handle wasn’t something that just screwed off but I would imagine since it’s a pull and turn that’s the reason it’s not….
pursang
07-09-2016 01:48 AM
Awhite9293
02-08-2016 03:49 PM
Chapman88SR5
05-17-2007 05:53 PM
RustBucket
02-14-2007 05:46 PM
Quick Reply: 88 Toyota pickup - "pull and turn" brake handle
