88 4Runner "Restoration"
Old 01-01-2013, 11:26 PM
  #121
RAD4Runner's Avatar
Originally Posted by jmc88runner
Thanks RAD, I checked those grounds and it didn't fix it. I looked all over and could find any other grounds so I'm stumped.
Headlights share power from same point on headlight relay, then that power splits to separate fuses for each side. I suggest with headlights on, you take voltage readings at different points on the way to left headlight. Do same onthe way to right lights. See where you get lower voltage compared to other side. Your connection upstream of that is probably bad. Good luck,
Old 01-01-2013, 11:50 PM
  #122
ChefYota4x4's Avatar
Was great meeting you, J .... Hope you get all the bugs figured out... It's a nice truck.
Hope to wheel with ya soon. Does your buddy with the Jeep go with ya often?
Old 01-02-2013, 03:47 PM
  #123
jmc88runner's Avatar
Yeah man likewise, we are both pretty busy so we dont go often.
Old 01-02-2013, 05:06 PM
  #124
Redeth005's Avatar
Hey i just read through your thread again. I seen you said you were prepping your truck for a new headliner. Where exactly are you getting it from? My top looks exactly like this. Only with much more taken off. But Ive been wanting to get another.
Btw you might wanna use a Putty Knife. I found it a hell of a lot easier to remove all the left over sponge and glue materials.
Old 01-08-2013, 06:16 PM
  #125
Ill either paint it or just get some off line somewhere.
Old 01-08-2013, 06:18 PM
  #126
Redeth005's Avatar
Dang. Thought you had a place online somewhere. oh well. Looks like im sticking to my original idea and putting on some carpeting up there to match the interior of the truck.
Old 02-04-2013, 09:45 AM
  #127
Hey guys, so a few weeks ago I took a impromptu trip to tr Azusa canyon. It's all fun untill I drove home. My cars not shifting into 4th anymore, under the driers side there's a slight noise with a sort of up and down motion going on(maybe the cv?) and my 4wheel drives not engaging in the front. And suggestions would be great and ill post some pics after work
Old 02-04-2013, 10:12 AM
  #128
4th and 4wd? Man, bummer! Check the fluids first, my girl had a leak I wasnt aware of and ran dry and I lost the 4th gear syncro. It wouldnt stay in 4th, only 4th. Then flushed and refilled, now it stays in fine but doesn't like the clutch involved, so she gets the dry shift, lol. But works fine til I wana spend the money. Also, my rear output shaft trans seal was draining thw trans into the transfer case til it was way over full. Then the rear tcase seal went, fixed that, but no drama during or thereafter on that. Maybe u gotz front drive shaft bindage really bad? Or the diff or tcase or cv's took a pooper? That really sux, watching for the videos
Old 02-06-2013, 05:13 PM
  #129
Old 02-06-2013, 05:15 PM
  #130
Before.
After.
Old 02-06-2013, 05:26 PM
  #131
HighLux's Avatar
The thought of cleaning that mud off...oh my.
Sweet truck. Love the graphics.
Backwards?
Old 02-06-2013, 05:27 PM
  #132
Wow, now dats sum dirty fun!
Old 02-06-2013, 06:35 PM
  #133
Backwards?
Yeah it was one hell of a car wash and I never noticed the backwards graphics until it was pointed out on this site.
Old 02-08-2013, 04:17 PM
  #134
Hey question for anyone I have to change my cv cause its toast, do I have to take apart the locking hub to do it or can I get around it?
Old 02-10-2013, 11:05 AM
  #135
XtraSlow_XtraCab's Avatar
Is it just the standard, "get out and lock it yourself" hub? If so, then no. The entire assembly can be removed, thus exposing the shaft nut. The cone washers can be a bear... bring a hammer.
Old 02-10-2013, 03:58 PM
  #136
what mirrors are those , 4runner looks nice
Old 01-09-2014, 10:06 PM
  #137
Thanks, dont know what mirrors they are they were on the car when i bought it
Old 01-10-2014, 07:31 AM
  #138
Redeth005's Avatar
Sup dude. I thought you had abandoned yotatech after selling your 4runner. You still lurking around in here? If I would have known you were still on I would have invited you and your wife to last weekend's camping offroad trip to Angels Crest! Lol how's the new 4runner treating you? Do you have a build thread for it?
Old 01-10-2014, 11:26 AM
  #139
priest16's Avatar
Transfer Case Gaskets?
I know this probably isn't the right place for this post but I'm looking for a quick answer and this seems to be a busy thread. I pulled my transfer case apart to do an inspection as I found major contamination in the oil and I can find a gasket/seal kit in stock for it anywhere. My question is could I just use gasket maker to seal up the case?
Old 01-11-2014, 12:40 PM
  #140
donomite49's Avatar
Liquid gasket is fine. The tc rebuild kit I got from trail gear came with thin paper gasket.
Quick Reply: 88 4Runner "Restoration"
