87 Pickup Dash Speakers
Thanks everyone for the info!
I think I'm going to try some of these:
https://www.amazon.com/gp/product/B0...A1SX1R00E2EUMR
With these baffles:
https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
ewong, did you have to do an modifications to get those foam baffles to fit?
Let me know,
Thanks!
With these baffles:
Let me know,
Thanks!
I used similar foam baffles made by XTC. The shallow version, though depth probably doesn't matter for the dash since there's so much room there.
I had to trim off about 1/4" from each side and pierce the screw and wire holes with a razor blade. That was about it.
It was a tight fit, but they went in with the original screws, too.
Those speakers will sound great. I wasn't even upgrading from stock speakers. I was upgrading from an older cheaper set of Pioneer speakers that also had integrated tweeters. These blow them away.
I probably cut the corners off a bit so it would not look raggedy.
The foam is soft and squishes into the hole.
Dunno if helps bass any - since they are 4"
It DOES keep the mouse poop off the speakers if the mice build a nest about the passenger side speaker...
3fingersalute
03-16-2016 08:09 AM
C2damuthafuqinLO
7
07-21-2002 09:27 AM
