87 Base Model gauge cluster conversion to SR5 Cluster questions
Old 10-10-2012 | 12:47 PM
kgb424's Avatar
got a 87 toyota pickup base model, so I bought a SR5 instrument cluster, got the right oil pressure sender too. I got oil pressure,volt meter,water temp, fuel gauge,all the lights work but no tach am I missing a connection some where, the guy I bought it from,say it worked before he pulled it, he is honest have bought parts from him before so I know he didn't screw me, I want a tach, a aftermarket tach is either in the way or it blocks your view,so thats why I bought the SR5 cluster to get a tach so is the some thing I'm missing
Old 10-10-2012 | 01:06 PM
87 4x4's Avatar
on the base you have to run a wire from under hood to the cluster. i had to do it on mine. ill see if i have the thread somewhere
Old 10-10-2012 | 01:07 PM
87 4x4's Avatar
its on here a little down
http://siestaoffroad.com/clustertech.html
Old 10-10-2012 | 01:28 PM
kgb424's Avatar
thanks I'm going to run a wire and see what happens
Old 10-10-2012 | 03:10 PM
kgb424's Avatar
thank you very much the tach works great now I can also change out the cluster on my 84 toyota truck too, cause I bought two clusters and two oil pressure senders for $120 I think I scored thanks again for the link
gary4runner
09-24-2015 12:53 AM
88yodabasket
07-13-2015 01:32 PM
Johntom240
7
07-13-2015 12:18 AM
hexrain
07-12-2015 01:13 PM
Cplmike
07-08-2015 08:47 PM
Quick Reply: 87 Base Model gauge cluster conversion to SR5 Cluster questions
