'86 Pickup IFS Suspension Help
Great help guys. It is really appreciated.
I've already started reading up on the correct way to adjust the torsions. Sounds like I can do that and maybe upgrade the shocks in the near future.
did you notice that the rear leafs look flat and are resting on the overload? Blocks are not the best way to lift leaf suspension. Very "agresive" shocks also dont absorb shock very well. And could contribute to a harsh ride. Take some more pics of the rear suspension. but it looks like your leafs are done.
What kind of leafs do you recommend for the rear? OEM with an aal, some emu dakars? Like I said, the block is 2 inches and I'd like to keep the same amount of lift.
welcome to the forum!
You may want to look at the ZUK mod for the rears if you're on a tight budget. I just did it and removed my 4" blocks - same lift, plus maybe an extra inch. Now I need to relax my T bars to even it up. Check out the pics in my sig's DIY.
good luck!
good luck!
#25
good luck!
good luck!
#26
#28
As you wish! Here are some crappy iphone pics. The truck isn't as raked as it looks. It's on a slight incline.
http://lh6.ggpht.com/_FXI2hLBhLDo/S7...oto%284%29.jpg
http://lh6.ggpht.com/_FXI2hLBhLDo/S7...oto%285%29.jpg
#29
very clean! looks nice!
looks like it's got the wrong year side mirrors on it though... -2 points
#30
#31
that will enter the right coding at the front and back of the link and make the pic post as a pic instead of just a link
#32
I just saw this at the end of your post. You're obviously right. They are universals that the previous owner put on right before I bought it. I hate them, and am looking for some OEM's at the moment, along with an SR5 cluster. It also didn't have a rear view mirror, but I got one from a member here. SO much better with the OEM rear view. He gave me a universal rear view to put on the windshield... no thanks.
#33
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
or if you have FireFox, right click on the image and "copy image location" Then paste that in the "insert image" after the image URL box pops up.
only do that to pics you know where they are coming from... If you do that enough an image can be swapped out for one that will get you banned... It's called "hot linking".
When you attach an image in your post, it's your and no one can change it's location.
That's the paperclip icon... and the images come from the pics on your computer.
If you setup a photobucket account you can copy all your pics to that and just hot link them and it won't use any of your attachments memory.
06-01-2021 01:51 PM
09-04-2015 09:27 AM
Vargntucson
07-04-2015 12:15 PM
