86-95 Pickup and 4Runner Headlight Conversions
Are you tired of driving down the road with the DIM factory headlights.
you know the ones that im talking about.
The old style Halogens, that emit a yellow, darkish color light.
If you are, you are in luck with the HEADLIGHT CONVERSION.
With this set up, you will go from the sealed glass lights to a nice set up.
It will have the replacement Headlight housing that is a durable plastic.
The bulb is switched to a H4 style bulb that is replaceable.
There is 2 different style bulbs that you can go with.
You can go with the regular H4 Halogen style bulb, this is going to be a little bright than what you have now.
Or you can upgrade that to the Vision X H4 bulb, this bulb is a step down from a HID..
With this your night driving problems are solved.
Less strain on your eyes as you are driving down some old 2 lane highway in the middle of nowhere. Or if you are like the guys here at LC, Some old dirt road or up in the mountains..
Check this out and let me know what you gentleman think..
Here are the links for you guys.
The 1st is the Regular H4 bulb
The 2nd is with the Vision X H4 bulb
http://www.lceperformance.com/H4-Hea...-p/3061016.htm
http://www.lceperformance.com/H4-Vis...-p/3061020.htm
With the Grill what year is it off of? More of what headlights are you using now?
If you are using the factory headlights, these will fit.
Andrew
Andrew
These are factory headlights on the 95 4runner. These are different from the 1990 4Runner.
Here is an example.
90
http://i597.photobucket.com/albums/t...g?t=1257385876
95
http://images.esellerpro.com/2133/I/...headlights.JPG
Here is an example.
90
95
Scotttekoch
23
11-01-2021 12:41 PM
bigblue82
10
07-06-2015 08:27 AM
