86-95 IFS 4x4 GEAR INFO - READ FIRST HERE NEWBS BEFORE POSTING
#42
OK so heres an interesting tid bit. According to the chart on here my truck (a stock 94 T100 4x4 with the 3.0 and an A340F auto tranny) came with a 2 pinion open 4.56 geared 7.5 inch rearend?!
I've searched and searched and read and then for good measure read some more. the axle code is A04A. Which throws me because its not the same type of axle code as the other trucks.
#44
Gear ratio
ive got a 89 pickup 22re 4x4 with 31's. Driving down the highway my engine sounds like its about to fall apart at 65. I know enough to know that that can be detrimental to gas mileage, and i do alot of highway drivin'. I cant tell what gears i have by the label inside my door (the idiot previous owner painted right over it.) does anybody have any idea what gears i might have and what i can change to for better highway driving. I mostly drive on road, but i like to take it offroad on the weekends.
#46
[QUOTE=kiyobrown;51794516]If it hasn't been messed with I would guess 4.10's. Find some 4.56's and you'll be set with 31's.[/QUOTE
Thanks, ill see if i can find some. I saw somewhere that you can get locking diffs out of a landcruiser. Is that true, and if so do you know what year range will swap?
#47
This thread is a beautiful thing! I'm new and until I figured out that switching the search function to search titles I was runnin around like a chicken with his head cut off...hope that helps someone else who reads this
Cheers from your friends up in B.C.
Merry xmas
Merry xmas
#48
#49
Hey guys I am noob but i have read this and other forums trying to figure out what i need and I'm still a little confused. I have an 88 runner 3" body lift zuk mod and its on 35's with the 3vze engine. Anyhow its a dog on the road i was looking for recommendations on gears. Also if i do change gears does that mean i only have to change the 3rd member? BTW this and many other threads have been so helpful thank you.
#50
#51
ok im gonna sound like a noob but i know alot about these trucks. but not much about rearends. i have a 1993 toyota pickup 4x4 v6 sr5 5 speed and my rearend just blew out onme and i needed to know if i can just swap it with a 4CLy rearend case i have one just laying around.
#60
ok i have found a 91 mazda b2000 or something like that its 4x4 6 bolt pattern and has a 4:30 gear ratio would that fit
also a 1996 honda passport v6 auto 4x4 in the manual it said it had 4:30 gears witha 6 bolt pattern
