50N Alignment question
I just got mine back from the dealer. They didn't do an alignment -- how far out does it have to be before they'll consider performing an alignment?
What dealer did it. I had mine done at Charlesglen. The should be putting it on the rack & checking the toe. If it is out of the spec range then they will adjust it. I received a printout from the dealer showing before & after & the specs. You should have at least gotten that.
It was at Sean Sargent Toyota, in Grande Prairie. I just got off the phone with them, and believe it or not, they didn't check because they don't have an alignment machine (so who knows what it's sitting at). But since it's a Friday at closing time, nobody's at the office anymore -- so it'll wait until Monday I suppose.
What a headache, I brought it in two months ago and they forgot to order the part -- so I came home empty handed that time. The good news is that they didn't try to sell me any parts I didn't need.
They should reimburse you the cost of having an alignment done at another shop. I'm surprised they don't have a deal worked out with somebody - can't believe a dealer doesn't have an alignment machine.
Check out the stickied threa at the top - several people have been through a similar situation with the alignment.
In there defense, they said that they are building an expansion that will have an alignment machine (but yeah, currently they have nothing). My experience with them in the past is that they are a very good dealer.
That said, they should have told me that they can't do alignment -- rather than just hoping that I didn't know that it was part of the recall. I'll let you guys know how it turns out.
Same thing happened when I went to my dealer. They told me it does not need to be aligned. The recall spec sheet clearly shows it does. When I showed it to them, that is when they told me they do not have an alignment machine. They said if I notice a difference in my alignment after the recall was done, I could have it done at another shop on and Toyota would pay for it. I have not had mine done yet because they want me to pull off my extra steering stabilizer first. I have a gut feeling that after I have it done, I am going to feel a difference in my alignment. Not to knock Toyota, but the dealer should have told me in the first place instead of hoping I would not notice too.
Well, they just returned my call... and according to them the recall does not include an alignment. I said it is a part of the campaign. They said it's not, so they're not paying for it to be done elsewhere. So as far as they're concerned, this case is closed.
I guess the next step is to bring this up with Toyota Canada, and go from there.
http://www.mudrunner.ca/other/toyotaSSC.pdf
Print this out. It is a PDF of the recall. Pages 2 and 18 clearly say the alignment is part of the recall. Bring it to them. If they still have a problem, call Toyota directly. Not your local dealer. Toyota likes to make their loyal customers happy.
Call Toyota if they dont' go for it. Dealers dont' like getting calls from the big bosses. My issue was resolved within 48 hours after I got a case number started.
They payed for mine and after taking to another dealership. Granted I am in the USA but it shouldn't make any difference. I wouldn't think that the recall procedures would be different from the USA to Canada.
Do we have any TOYOTA tech's here from Canada that could be of any help ?
Yeah, I was told to phone the local dealer and speak directly to the service manager.
The stupid thing is that the alignment was pretty much the only reason I took it in for the recall.
OMFG! I just got off the phone with Toyota Canada and...
THEY SAID THE ALIGNMENT IS NOT PART OF THE RECALL.
That's right, there is no alignment according to 1-888-TOYOTA-8. So suck it up Caffeine, because you don't even get to put your truck on an alignment machine, much less get it aligned.
Does anyone have a copy of the Canadian SSC document (#514)?
WRONG!!!!! Tell them to read it again. A full alignment is not included but the toe adjustment is. Some dealers say that it isn't but if they read the document it is. I had one dealer that originally said that the toe wasn't included until I told him to go get the document. He read it and said yah it is included. Then I asked how much for the other adjustments. He quoted me a full alignment. I asked - so does that mean you are double billing for the work - he declined to answer.
Yeah, well that doesn't help me right now. Both the dealer and Toyota Canada have just told me to go fly a kite -- so unless I can get my hands on the Canadian SSC I'm pretty much SOL.
I've phone both the dealer and toyota a couple times a piece, and I'm just hitting a brick wall.
Well a full alignment is not part of the ssc. There are labor times for1. replacing the steering rod at checking toe( which is done with just a tape measure by the book), 2. Replace rod, check and adjust toe, and 3. replace rod and full alignment. We all way align them because it pays an extra 1.5hrs, but it is not required. The only time will don't align them is when there is parts with alot of play( TRE's, idler arm, ect) and the customer wont replace them.
