4X plug #3 has fouled
Old 09-02-2007, 09:05 PM
Itoyota's Avatar
once every tank of gas. and it burns/leaks almost 1/3 of the dipstick (hashed area between E and F)
Old 09-03-2007, 09:58 PM
stormin94's Avatar
RINGS. I know all about this one. My Jet Ski smoked, too. the #3 and #4 cylenders both had badly fouled plugs. I spent $49 on 4 spark plugs.....and they fouled up again! I say rings.
Old 09-04-2007, 06:06 PM
Itoyota's Avatar
No. It's the valve. But thanks anyway. Jet skis are way different from the 22re bud.
Old 09-04-2007, 06:51 PM
longhungsilver's Avatar
rofl
quite the oil consumption u got there... Id say valve as well
Old 09-04-2007, 09:47 PM
  #25
stormin94's Avatar
Originally Posted by longhungsilver
rofl
Yeah, if you tear them apart, it's an inline 4cylender...but that's probably where any similaritys end. The Jet Ski was made to run at 7000RPM for extended periods of time, and makes around 165 Horsepower off of 1.2 liters. The 22RE was made to run slowly, but for a LONG LONG LONG time!!!
Old 09-05-2007, 11:36 AM
  #26
dcg9381's Avatar
I've found that ring failures are much more common than valve seal failures on these motors, but it is a bit odd to be fouling a single plug that bad.. All I have to say is "wow".
Might leak down test it (checks the rings).
If it's really bad, it would probably show up as a difference in compression also.
Old 09-05-2007, 03:50 PM
  #27
Itoyota's Avatar
compression has been done, leak down that is, as well as a straight up check. 160 across all four. the engine has JUST BEEN REBUILT, there's the pity in it. Ive got an anti fouler in we'll see how long that holds out.
Old 09-17-2007, 04:13 PM
  #28
Itoyota's Avatar
Well. to fix the problem with the small miss that kept developing from # 3 fouling i put in an antifouler. It's been a good three fuel tanks lots of stop and go as well as high RPM off road usage for 2 hrs. I got it home and noticed a strong miss. Popped out number three, and you wouldn't believe it if i told you. A brand new NGK v-power plug worn through the ceramic clear down from the ground strap (which also managed to grow tumors on both sides) Soloutions? do i need to go to a cooler plug? I have Bosch Platinums that i will put in to hold me over.
Old 09-17-2007, 05:09 PM
  #29
Itoyota's Avatar
Old 09-17-2007, 07:51 PM
  #30
dcg9381's Avatar
I can't see the photo, but yikes...
Does it run funny before fouling - any chance of an open injector or too tight a rocker arm...
Oil control ring installed upside down?
Old 09-18-2007, 07:07 AM
  #31
Itoyota's Avatar
never thought of the oil ring being upside down, i didn't know you could do that. I had it rebuilt by some pro machinists tho, so i doubt it but it's not impossible. It doesn't miss once it's warmed up. So it runs great and is hella powerfull.
Old 09-18-2007, 07:24 PM
  #32
Itoyota's Avatar
no one with any ideas? what happened to all the motorheads round these parts? I remember getting everything from the dumbest advice to the greatest professional help. Looks like we are all too busy watching you tube vids.
Blamalam
03-12-2022 07:34 AM
old87yota
10-25-2015 02:15 PM
Sidherish
08-02-2015 01:42 PM
msane99
07-17-2015 10:13 AM
Quick Reply: 4X plug #3 has fouled
