4wd drive locking hubs conversion.
I was gonna to finish up my swap from add to manual hub but when I pushed my hub over the gear I to lock it in place I accidentally weny a little to far and went over the gear. I can't get it to slide back over the gear to engage the 4wd permenatly this is he picture of what it looks like. I tried prying into position but no luck. Any suggestions to move it into place.
This is the tutorial I followed
hwww.4x4wire.com/toyota/tech/add/
If you guys have any advice call.me 5035758892
Just sent you a text.
For future reference if anyone else is struggling with this, simply jack the driver side of the truck and rotate the tire forwards and backwards slowly until the gear can slide back over. I hope this helps others too. I did the same exact thing and couldn't figure out why my 4x4 was still not working after putting it all back together.
anniesball
03-01-2012 01:18 PM
