4runner 1994 steering box help
Hi after changing the steering box the steering wheel is 1/2 turn left so I am trying to put it straight.... how to find the dead center spot of the steering box . or how to put de steering wheel the good way
thanks
thanks
the way a proceed is the truck on the grounwd it is better to put the truck on jack stand ???
thanks
Question it possible to alligne the mark whitout remove the tie rod because those fork damage the joint boots it so how to proceed plz .
check link http://www.fourwheeler.com/how-to/su...ckup-steering/
thanks
thanks
Do not use a "pickle fork."
It's the mark of an amateur, and as harleyman711 says (I think) it will damage the boot. Heck, it will damage everything it touches.
Just use the right tool. http://www.harborfreight.com/tie-rod...ller-1752.html (multiple sizes available).
I guess you all can call me amateur I always use a pickle fork because if those parts come off new ones go on. I am not worried about damaging a rubber boot in something getting thrown out.
Although the torch is always my first option !!!
That does not mean I don`t have the pullers
After a test run of a few miles getting a feel for where the steering wheel wants to be.
The way I line the steering wheel up is get the front wheels straight .
Pop the steering wheel off put it on as close to straight as possible.
Put the steering wheel back on take it for a ride.
Doing this only if it is really off .
It is the only way I have ever done it If there is a better way outside a front end rack I am willing to learn
Hey nice to read all of you guys about the fork to day I buy a nice puller but it is a little bit to tight to go true the tie rod https://buytools.ca/eng/pitman-arm-p...7148-2720.html
so now after your argument what is the best way to aligned the wheel and streering wheel ???
thanks
thanks
Nice Day today fix all the steering Wheel problem jack up the front and align the mark on the steering box and the one on the pitman am and I ad to 1/2 turn of the u-joint column everything is strait now .
thanks for your help
Road Bull
10-10-2015 04:55 PM
skoti89
07-08-2015 12:05 AM
