400 hp 3.0 Ivan Steward motor
Old 07-24-2007 | 05:10 PM
olharleyman's Avatar
Found this on e-bay thought someone might like it
TRD 3.0L 3VZ Ivan "Iron Man" Stewart Baja Race Engine
Custom-made, TRD Works Engine Built for Ivan Stewart Item number: 110150161562
Own a piece of history!!! This is a custom-built race engine. All parts specially cast, made and machined by Toyota Racing Development's Race Engine shop, the same folks making the NASCAR race motors. Back when Ivan "the Iron Man" Stewart was fully factory backed with a small army of Toyota technicians and engineers, TRD and PPI hand built a limited run of 3.0L engines to dominate SCORE Baja racing and they DID! Capable of nearly 400 horsepower on a full on race tune, these motors carried Ivan Stewart to multiple Baja 500 and 1000 wins. Most of the motors and parts disappeared to collectors or TRD scrap parts bins but this one got away. It lurked in the shadows of TRD until it was put back into action in a Class 7S race truck by a TRD engineer in 2001. He raced a year or so then sold the truck to the Long Beach Racers who campaigned the truck and WON the Baja 1000 on this motor in 2004. This is a winning, strong motor built with Toyota reliability. The Long Beach Racers ran the truck another 2 years and wanted to switch to Class 7SX which allows for 3.4L motors and more competition. During the Baja 250, they spun a bearing and instead of rebuilding the motor, they decided to make the switch to 3.4L. So if you're looking for a high horsepower motor to run or race or you want to put a piece of history on display in your showroom, this is the last chance for this motor to be available. If you could even get TRD to make you one of these, you'd pay a couple hundred grand or more. The heads are one-off castings for high flow with matching intakes, dry sumped, girdled block, etc. If you know racing and Baja racing at that, you know how rare this opportunity is. Auction includes: TRD 3VZ Racing Engine, including dry sump and pump, ECU's and headers. Basically a complete engine that needs a bottom end rebuild. Spare Parts: Lots of spare sheet metal timing belt covers, etc. 3 cam shafts 1 crankshaft 3 dry sump pans 3 main bearing supports / crank position sensor mounts 4 sets of heads 4 intake manifolds 2 injection systems 1 set of valve covers 1 power steering reservoir 6 ignition coils 7 cam pulleys Lots of spare valves and springs, both new and used Braded stainless steel Dry sump lines with AN fittings 160 amp alternator 1 Ultra Filter oil filter can Extra oil lines 15 velocity stacks 2 crankshaft pulleys New distributor cap TIG welded chrome moly motor mounts I have more pictures with better shots of the spare parts I will email to bidders. Sorry, eBay limits the amounts of pictures I can post.
Old 07-24-2007 | 05:27 PM
Jay351's Avatar
A performance shop should buy it, and clone the parts used!
I would LOVE to have a 400hp 3.0
Old 07-24-2007 | 05:32 PM
frodin1's Avatar
I think he's still factory backed. I saw him on a show and they were in Glen Hellen, doing a race. He's the one setting all these races up. It's not CORE I don't think. Maybe it is I don't know. It was the tail end of the show and they were interviewing him. He still had on his trademark TRD collard shirt?
icentropy
09-16-2020 02:47 PM
93toyoguy
08-02-2015 07:41 PM
tobylab
Diesel Swaps
07-17-2015 06:51 PM
tobylab
07-12-2015 12:53 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: 400 hp 3.0 Ivan Steward motor
