40" tires on 2nd gen!
Originally Posted by Flygtenstein
If you don't get Mogs you won't get the truck.
Originally Posted by Diesel_Freak
looks like a neat build-up, but it's a little pointless, the rear wheels cat't really articulate up much cause they're about a foot back in the well... like I said, neat build up, bgut not really a good trail rig... it'd be sweet in the mud tho I'd assume, can you say float?
Originally Posted by dwh91102
thats the same thing I was thinking, looks like you could stuff a tire up about an inch, before it was ripping the back bumper off. Cool rig I guess if you got the money.
#25
Not just celarance, but they also have gear reduction hubs (Which is what creates the clearance).
If I ever SAS'd mine, I would deifnitely consider going with mog axles. I know tehy are pricey, but how bad are we talkin?
#26
Lookin at around 3k...the guy with that 4runner claims he put almost 20k into it.
Mog 404s: http://www.pirate4x4.com/forum/showthread.php?t=393332
Mog 406s: http://www.pirate4x4.com/forum/showt...ghlight=portal
Volvo Portals: (slightly weaker) http://www.pirate4x4.com/forum/showt...ghlight=portal
That is a sweet rig is been following the build up on pbb for a while now.
#27
3000 for a pair of volvos. that doesn't sound unreasonable to me. I'm sure parts to rebuild them are more expensive due to scarcity, but to me the originality and ground clearance and strength are well worth the cost.
#28
#29
Originally Posted by rocket
When i was looking at it, i noticed the same thing but when i saw how the suspension works (4 link?) i could tell the rear wheels would articulate up at an angle towards the center like so \
Doc, do you think I'd put it to good use if I owned it?
Chris
#30
Oh, it works all right. I have been watching this bad boy for a long time. As far as I know he hasnt wheeled it yet, I remember him saying it was going to colorado to get something done to it but I can not remember what.
#32
Originally Posted by phorunninduke
OH yeah, it was for an exhaust system or something like that.
Props to the guy for the dream and the ingenuity, but I really don't get it...
It should be noted that I drive MOGS in the summer for a Wildland (Fire) rig... they're really fun just the way they are...
#33
to have them finish up installing an ARB compressor and a bunch of other wiring.
#34
Originally Posted by ravencr
If it works well, I'm definitely jealous. I'm not a fan of the airbags, but they do have some serious advantages for off-camber.
Chris
Chris
I KNOW that it would not be clean and certainly would have scratches and scrapes ! But - ain't that the point ?
#35
Originally Posted by Doc279
Chris,
Chris
#36
guess I am a little late to the party!
Wierd to see pics of MY rig on another site that I didn't take and post myself. Kudos to the photographer, you did the rig justice!
Yes I did tow it 700 some odd miles to get the exhaust and some wiring and fuel line work done. They are building custom exhaust from the header all the way back-- all stainless.
It has 175K miles on it and believe it or not, a lot of wheeling miles around Colorado. I am from Montrose and live and work in St. Louis. My family has a ranch in Montrose so I am out there several times a year to help out and vacation too. I bought the rig new and have taken very good care of it. It had 32" BFG's and a 2 in lift for the first decade and then I pulled the trigger on this undertaking! Actually I collected parts for about 2 years and it took almost a year to have my custom 404's built in Canada--most of which was spent waiting for CTIS unions. A lot of custom work was done to make the rotation unions fit the 404 hub bolts-- the bolts had to be completely custom machined but they are awesome. Exaxt did all of the work on the axles.
Yes it has been expensive but the end result will be greater than the sum of the parts in my opinion.
Goal # 1 was to fit Unimog portal axles under my rig--instant 6" lift!
#2 fit it in my 7" garage so I can daily drive it
and goal #2 is why I chose airbags and insisted on CTIS.
But it will get wheeled, friends, and plenty, for many years to come!
Lastly-- it isn't a ARB compressor folks, it is an Oasis 1000 on 24 volts that puts out 16 cubic feet per minute of air at 100 psi!
For comparison, Toyota Owner Magazine did a test of all popular compressors including the Oasis. And that was on 12 volts where it only put out 8 CFM.
Why?
This AiRock system FLAT EATS UP CFM as it cycles and is only as fast as the compressor and tank--but it will blow through the tank in just seconds so I really needed a lot of air, and for extended periods, all done as reliably as possible. For example-- on DEMO mode-- yes it has a demo mode where it does FBSS like a carnival ride until you shut it off-- it blows through a 15 pound tank of CO2 in about 3-5 minutes! So I have the compressor and a 5 gal tank and two 15# PowerTanks as backup.
Why?
#37
Also, the airbag system is computer controlled and is fast enough to compensate for body roll on the street and the advantages off road are endless--body stays level in off camber situations and weight is transferred uphill while climbing and onto the back wheels while decending a hill.
#38
Originally Posted by Spectre
Besides the 3.0 and the body...whats still a toyota?
#39
he had to send it to another state to get an exhaust system done??? or is the guy IN Col.? Cause that'a bloody bigger waste of money than the project in general if he sent it out of state...
#40
Chris
