3VZE TOP END+homemade ??Y PIPE?? MOD!!!
Old 05-15-2007, 07:16 PM
  #41
ChickenLover's Avatar
Originally Posted by Chief_Yota
do i have to mash it down or wut?
No, don't mash anything. It should slide in there easily. Your gears just aren't lining up. Rotate your dist and/or cam slightly.
Old 05-15-2007, 07:18 PM
  #42
gonzo's Avatar
use some ky on the seal
Old 05-16-2007, 04:52 AM
  #43
chimmike's Avatar
Man, those crush bends are nasty on that exhaust!
Old 05-16-2007, 05:09 AM
  #44
mikewic's Avatar
the oring is stopping it form seating, use some oil ont he o-ring and it shoudl slide in. you may have to twist it some and put some pressure to get it in, but it should go.
Old 05-16-2007, 05:23 AM
  #45
OSIRIS's Avatar
i bought myself a micro ajusting torque wrench for putting things back correctly. cause that old one just aint that precise and it only goes to 60l-ft
That's a powerful tool you have!!! I can't tell if I lookin' at yotatech pics or porno!!
Old 05-16-2007, 05:40 AM
  #46
OSIRIS's Avatar
What is the purpose of making the Chief pipe mod?
Is it to help with the #6 exhaust from getting overheated and HG overheated back there to prevent another blown gasket?
Is it to help increase power?
In both cases, running another crossover pipe, albeit in another location back to the original stock left side exhaust manifold (driver's side) will not solve either of those issues.
If you have the ability to cut and weld exhaust pipes, then you should seal the driver's side cross over inlet and weld a Y-pipe further down. This would help alleviate the heating issues for the Number 6 cylinder. The problem is the whole right bank dumps it's heated exhaust right there at number 6 and it sounds as if your mod would still do the same thing if you are using the stocker manifold.
Am I understanding correctly what you are doing??
Osiris
Old 05-16-2007, 05:57 AM
  #47
aviator's Avatar
no he's running the cross over pipe lower down running it around the tranny I think... kind of like a NWOR header setup if I understood him right...
nice write up chief lotsa pics... did you install a set of weasy2k's cams?
Old 05-16-2007, 06:15 AM
  #48
TNRabbit's Avatar
Did you wiggle the cam while trying it?
Old 05-16-2007, 06:20 PM
  #49
Chief_Yota's Avatar
alright
first my camera is pur crap so,if i didnt had my crapy camera i had to take pics wit my cell phone,aanyway.so heres the chief pipe mod deal all about,im making a drawing right now ill post later tonight;
im gonna CANCEL my cross over pipe ,byebye,in the trash,next that would physicaly leave two holes in the original setup ,one on the left side (from front)that supose to get back to numb 6 and the one thats on the right side (from front )that connect that same cross over to the previous side. NOW im gonna close that hole on that right side from cross over than keep the original setup that goes down to your o2 sensor as in the previous picture. now follow closely,for the left side im gonna cut the old cross over end and weld a down pipe to it so i can bolt that thing in the left side. and to finish im just gonna make an elbow to connect that side to my other side just BEFORE the O2 sensor .As for performance im not expecting a change. its just to cancel the over heating problem.
Old 05-16-2007, 07:37 PM
  #50
Chief_Yota's Avatar
ok i know im pure crap at photoshop ,so plz no comments:
Old 05-16-2007, 07:48 PM
  #51
Chief_Yota's Avatar
Old 05-16-2007, 08:56 PM
  #52
Chief_Yota's Avatar
as for all the wires near the new pipe area im gonna tape them wit some high temp resistant stuff.
Old 05-17-2007, 08:54 AM
  #53
aviator's Avatar
I knew it! haha
Chief you want to be careful with your clearances as you cross over the front driveshaft...
wait a minute your sig says you have a lift so it should'nt be a problem...
Old 05-17-2007, 09:50 AM
  #54
OSIRIS's Avatar
Why don't you just do this?
You would cure the heat issue you want to deal with and you are using the existing location for that crossover section of exhaust. If you bottom out over a rock, you would crush that exhaust under the tranny.
Old 05-17-2007, 10:14 AM
  #55
Chief_Yota's Avatar
cause i wanna get rid of my god damn crossover manifold,and i think that witout it ,theres gonna be less heat around the head gasket back there.as for the clearance ,there is no problem with that i got like one feet or more between the shaft and tranny thx to my susp lift. anyway is a good thing u said that cause i dont know if its gonna fit witout a lift actualy...
Old 05-17-2007, 10:20 AM
  #56
Chief_Yota's Avatar
as for the rock issue ,dude first of all that shaft is strait solid ,it doesnt move freely up and down ,and my new pipe is right over it,so if get a rock its gonna hit my shaft not my pipe!! and basicaly its pretty rare you hit your front shaft on a rock ,if your not doing some insane rock climbing witch i dont.
Old 05-17-2007, 01:54 PM
  #57
Bumpin' Yota's Avatar
I see that I started a trend by painting my plenum and valve covers black!
What performance mods have you done? An extra 30hp can be pulled out of the heads alone...before the cams.
Old 05-17-2007, 07:57 PM
  #58
Chief_Yota's Avatar
hey bumpin,well yea i had choice of colors but im more into some nice and clean black then some candy pink ,know wut i meen,anyway as for performance ,I JUST WANT A DESCENT FUEL MILAGE,thats it!! i didnt get any port and polish ,or OS valves or any of that expensive stuff.just the basic.but if you have any good mod that i should take a look at ,feel free to post it up.
Old 05-17-2007, 08:19 PM
  #59
Chief_Yota's Avatar
hahaha ,heres my performance mods :
Old 05-17-2007, 09:43 PM
  #60
Chief_Yota's Avatar
Quick Reply: 3VZE TOP END+homemade ??Y PIPE?? MOD!!!
