3VZE Engine Harness Question
I'm pulling the heads on my 1992 3VZE. After I removed the intake chamber I could see the 2 wiring harness branches for the fuel injectors. They are sort of encased in plastic box-like things that are hooked to the valve covers.
The left side was OK, but the right side plastic box-like thing was very brittle and had already cracked quite badly. It is not salvageable.
Does anyone know the part number(s) for these things? They don't show up in TradeMotion.
Thanks in advance for any suggestions, I really appreciate this site.
there is no part number for them without replacing the whole harness. Those plastic keepers turn brittle fairly quickly after new due to heat and oil.
You could wrap them in a wire loom, then tape them up good so it looks stock and keeps it protected.
TURBOrunnerNM
07-22-2015 12:01 PM
