33x10.50 Will they rub?
I ran 33x10.5's on stock wheels for a year, and never rubbed. I had BJ spacers and 1.5" Downey coils, and later switched to FJ80 coils. Worked perfect!!
With Downey coils
With Cruiser coils
With Downey coils
With Cruiser coils
I had 33's x 10.5 on my 89 runner and it never rubbed. although once i ran 12.5's that's the only time it ever rubbed. The wheels I had them on had a 4" backspacing. Anything more than that would be questionable.
wow, exactly one year ago: I had 33x10.50x15's WITH a 1" 4crawler body lift and both my fenders were destroyed from a stupid little ditch. I believe the same thing could of happened in rocks. I guess if your extra careful then no worries but theres always a possibility of the inevitable... https://www.yotatech.com/forums/f116/1-bl-33s-finally-hits-home-74800/ ...just something to think about.
#25
Hello,
I've been looking on here for the past 1 hour and I am wondering if 33x10.50's will rub. It's and 88 runner with bj spacers and shackles and aal. Some said that they will rub while others said they don't. If they rub how bad will they? What can you trim? What is the pinch weld? I have fender flares.
Aaron
Aaron
#27
Definitely. I don't think my 34x9.50 would rub if they were mounted on the factory rims - that extra 1/2" of bacspacing makes a HUGE difference.
#28
my 33x10.5 bfg a/ts are mounted on factory aluminum rims and they rub the pinch weld and valence going around corners and when the suspension is compressed. i still have to hammer the pinch weld and i've got balljoint spacers to install but neither of those things will help the rubbing on compression.. which i'm worried about for wheeling. we'll see i guess.
#29
If the torsion bars were mounted to the LOWER arms then yes, BJ spacers would obviously become pointless, but I just do not understand other people's logic behind this.
If the spacers don't provide lift, won't help clear larger tires, and only place more stress on the steering linkage and CV's, what's the point??
[/Hijack off]
On a more related note, how would optimal BS change in comparison of a 10.5 to a 12.5 width tire?
#30
BJ spacers don't help on compression because the lower arm compresses to the same point with or without BJ spacers. If you want to reduce up travel you have to extend the bumpstop.
#31
does the ball joint spacer influence the center point of the wheel in relation to the path of travel of the control arm? if so, it moves the wheel's center lower, then the spacer contributes the thickness of the spacer to the amount of clearance at the top of the tire, right?
#32
#33
I just bought some 33x10.50s. I was looking at the 9.50s, but the tire rep said that they're discontinuing them. Something about people wanting great, big, freakishly wide tires now. Just a heads up that you might want to grab a couple extra in case you wreck yours.
#36
I don't see the point in getting huge tires that are not wide. I would never get like 35-10.50's. It's just too much of a hassle to regear, and stuff, and I can't really find any real benefits to getting huge, skinny tires.
#37
tire diameter is probably most important. http://www.4x4now.com/sfjun96.htm is a good reason. notice the footprint is much more affected by the overall circumference of the tire than the width. the bigger the diameter the more traction when aired down. it's almost like a tracked vehicle at that point, only better for what we do because it conforms.
with that in mind, i run 32x11.50s and 35x15.50s I think width is also a good thing. i would rather have a tall wide tire than a tall skinny tire any day. but i think the tall skinny tire would be the best bang for your buck, because you probably wont need much of a lift and youll get the largest footprint for dollars spent.
#38
For the same amount of lift, you can fit a taller tire if it's narrower. The only effective way to get ground clearance under the diffs is taller tires. The argument of flotation vs dig can be argued til you're blue in the face, but clearance is clearance.
I ran the 34x9.50-15 TSL's on AR767 15x8rims with 4-1/8 backspacing and they rubbed pretty significantly even after pinchweld and some trimming. DO NOT run them on 8" rims - I suffered tons of rim damage flats with them. I think with stock rims they would have rubbed a lot less.
#39
THis is all very interesting to me cuz I was thinking of getting 33s for my 88 v6 4Runner with no lift. Should I keep my stock rims and go bigger or get other rims and get 4" BS? Anyway, I am confused. I have heard that 33s will fit with no lift but you have to trim a little and or use the BFH, with 1" wheel spacers and a 1" body lift.
Who knows where to get body lifts with an automatic tranny? Can it be done?
83yotastockR
11
11-10-2015 06:54 AM
myotherrideisayoshi
09-29-2015 05:41 AM
sonorn67
09-19-2015 05:39 PM
