3.0 Low Idle When Stationary
Old 07-07-2010, 06:06 PM
norcal707's Avatar
if you leave your TPS disconnected, your mileage is going to be bad and your check engine light is going to be on....check the ohms on your tps to see if you need to adjusted or replace it....i'm having the same problem with my tps, thats why I couldnt pass my smog test...
Old 07-07-2010, 06:09 PM
95blackToy's Avatar
mine just started doing it. i didnt pass smog a while back due to my blown head gasket. after that it passed. do i check the ohms with the motor running? what should it read?
Old 07-07-2010, 06:14 PM
norcal707's Avatar
no, you need to take off the body throttle off from the engine, there's a link to download the manual for this truck here at yotatech. is one the is stinky, on top of the list of tread....
Old 07-07-2010, 06:16 PM
95blackToy's Avatar
is there a way to keep all of the coolant from pouring out of those hoses attached to the throttle body?or a way to do it on the truck so that i dont have to fool with those
Old 07-07-2010, 06:21 PM
  #25
norcal707's Avatar
what I would do is find some bolts with the same diameter of the hose...take off the hose from the throttle body and put the bolt on the hose and used the some hose clamp.
Old 07-07-2010, 06:27 PM
  #26
95blackToy's Avatar
alright so i do the check by putting the ohm meter on each post and move the throttle around, correct?
Old 07-07-2010, 06:31 PM
  #27
95blackToy's Avatar
thanks man il look at that fsm on how to test it.and hopefully get that fixed. Thanks to everyone else too who put into this thread.
Old 07-07-2010, 11:50 PM
  #28
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Originally Posted by iamsuperbleeder
here let me help you with that
looks like just an access point to something? did tightening it back up fix the problem?
I have no idea... not a 3.0l guy
That's the cap for the internals of the idle air control valve.
Old 07-08-2010, 06:25 AM
  #29
Fink's Avatar
I changed the name of your thread by the way - the other one was way too ambiguous.
If you don't like this one then give me another more descriptive one and I'll change it for you.
I'm going to unsubscribe to this thread so just shoot me a PM with it.
Fink
Old 07-09-2010, 01:34 PM
  #30
95blackToy's Avatar
Hey guys, i am in the process of checking my tps. When i do the resistance check they all seem to be within standard. Accept from terminal IDL-E2 isn't even getting a reading. could this mean i need a new tps? Here is a link to the test. http://www.the-roo.com/4runner/Engin...m/throttle.pdf.It would seem that there is something wrong with the IDL terminal.
Charecter1
11-06-2023 10:08 AM
Alex Bessinger
08-31-2015 09:17 AM
luckypig44
07-19-2015 11:25 AM
kyletbert
07-17-2015 11:39 AM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: 3.0 Low Idle When Stationary
