3.0 to 22r swap?
Old 09-29-2005 | 03:37 PM
timw.'s Avatar
3.0 to 22r swap?
I was wondering if anyone out there has ever heard of actually swapping out a 3.0 with a 4 banger in a 2nd gen. 4runner? I've always had an affinity for 22r's and am tired of paying for fuel with the 3.0 (not to mention dealing with the pesky a340h tranny). this actually brings me to my second question, would I also have to switch to a different transmission? I don't necessarily have a problem with auto trannies but have had a number of problems with my a340h. Thanks in advance for any input.
btw--if swap is possible (as well as plausible), what would be an approximate cost for this massive transformation?
Old 09-29-2005 | 03:54 PM
6lug's Avatar
man i hate the a340h, and if i could i would swap it out for the w56 anyday. sorry to stick that in here but i would. now if youre gonna swap in a 4banger, the squirrels are gonna have a harder time with an auto. You know how bad the performance of the 3.0 is with the auto? it has to be even worse with a 4 cyl. If youre gonna swap, id say go all the way and get the 5 speed also. Plus, you cant regear the transfer case on the a340h because you cant take it apart. with a 5 speed you can add a crawler or regear. just my opinion
Old 09-29-2005 | 03:58 PM
EWAYota's Avatar
you probably can't due to emissions testing. You have to put in a motor of the same year or newer.
Old 09-29-2005 | 04:06 PM
timw.'s Avatar
pardon my ignorance on this but would you happen to know the motor from a 92 or newer? Is it a 2.4? 2.7? any idea on estimates to make that transition? Also, I bet it would be considerably more expensive to swap from a auto to a 5 spd huh? btw, i appreciate everyones input. thanks a bunch
Old 09-29-2005 | 04:38 PM
jimbo74's Avatar
toyota used both a 2.4 and 2.7 engines... however the 2.7s didnt come out as the 4 cylinder until the tacoma in 95
before the tacoma the 4 cylinder engine was the 2.4l 22r or 22re
Old 09-29-2005 | 07:06 PM
kyle_22r's Avatar
the 22R was produced from '81-90 in the US and the 22R-E was produced from '83-95. after that, the tacomas came with the 2.4l 2RZ-FE and the 2.7l 3RZ-FE.
Old 09-29-2005 | 09:16 PM
Scottz's Avatar
No the trannys are not compatible. If you want auto you will have to stick in a40. With a 22R I would recommend a 5 speed so you can get a little more power.
Old 09-29-2005 | 09:58 PM
Adam F's Avatar
You'd be better off selling the 6cy rig and buying a different truck.
Get a 1st gen instead!
Old 12-09-2007 | 12:05 AM
toyx4fun's Avatar
I am planning the same swap...
I recently purchased a 94 pick-up with an LC engeneering 4 cylinder and a W56 with double boxes it already has a solid axle so all of this will be transfered over to my 4runner and I would imagine that all the wiring mounts and accessories will make the swap a piece of cake! My only chalenge will be the front suspension...
Old 12-09-2007 | 12:24 AM
misterzee's Avatar
X2 ! finding a 4cyl 4x4 2nd gen is difficult!!!
tobylab
01-18-2016 08:06 PM
Alex Bessinger
08-31-2015 10:17 AM
keithporter83
07-24-2015 08:37 AM
tobylab
07-12-2015 01:53 PM
Coreyr384
07-10-2015 12:13 PM
