2wd headers for 3.0
Pretty sure the only reason that companies claim that the headers only fit 4WD trucks is because of the crossover. You shouldn't have an issue putting the headers on and just reworking the crossover a little bit.
Toyota 3VZE 3.0L V6 Engine Hi-Pro 190HP/210ftlbs
From raptor engine.. has anyone heard or used this motor before.. trying to get headers for this when I drop in the motor..
The following users liked this post:
wacked (03-13-2021)
thank you for your quick reply, so as far the fitting it in they should bolt up hopefully they fit between the frame and the steering shaft nicely and from the flange to the cross over some modding will be made.. which is no problem. But as long as the LT headers fit .. btw I am currently building a
From raptor engine.. has anyone heard or used this motor before.. trying to get headers for this when I drop in the motor..I've heard of the engine before but there hasn't been too much information about longevity posted on this forum. There's a few threads that mention it, if you use the search bar.
Personally, I'd rather 3.4 swap it for the money.
WTB[PacSoWest]: Doug Thorley 3.0 long tube headers and aftermarket cams
stevennc
06-17-2017 04:19 PM
Ninja 85
09-13-2010 11:38 AM
Ilovemountains
01-22-2010 07:04 AM
