2nd generation stock ride height
I've done some searching and still haven't found the answer to what I'm looking for and hoping some of you can help out. I've been trying to find the measurements for the stock ride on the rear of my 95 4runner. I just replaced my rear coils with the moog coils and only gained around 3/4". All the measurements I've found online Seem to either be from top of rim to fender or somewhere on the body from the ground. Problem with those is that most didn't specify of they were running a 15 or 16 inch wheel and from the ground to body leaves variances if the ground isn't completely flat and also exactly where to on the body. Anyway, I took measurements from center hub to fender which seems to make more sense and much more accurate. I'm looking for measure from others who have done it this way. My drivers side with the new coils is 20 1/2 inches and passenger side is 20 3/4. With old coils driver side was 19 3/4 and passenger side 20. This is with an empty tank of gas. I'm curious as to what others have measured and figured I would get and 1-1 1/2 inches with the new moog coils. Thanks!
Flying91
45
04-11-2024 04:39 PM
