Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
- Toyota 4Runner 1984-1995 How to Replace Shock Absorbers
Step by step instructions for do-it-yourself repairs
2nd Gen 4runner Pro Comp Shocks (Pics)
I changed my shocks a few weeks ago because they desperately needed it. After some research I ended up going with the Pro Comp ES9000s because of the price and the local 4wheel Parts store had them. Shocks are relatively simple to install and I recommend doing it yourself if you think you can.
Tools needed:
-Metric socket set
-American Socket set (for the new shocks)
-PB Blaster/WD 40
-Breaker bar
-Pickle fork (steering stabilizer) and a BFH!!!
Optional tools
-Jack and jack stands
These were my 14 year old stock shocks on my 1993 4runner.
Front:
Rear:
As you can see they are worn out. In fact when I took of the rear shocks They didnt extend and you could hear the oil slosh around. Not good! Here are some pics comparing the stock to the procomps.
Fronts:
And the Rears:
Here they are installed. I was nervous about them fitting right but the lengths and clearances were fine.
Front:
Rear:
The last thing is the steering stabilizer. The stock one was piratically dry inside and there was oil all around it.
Before:
After:
Overall I am extremely happy with the results. The ride is 100% better than it was before. The shocks are pretty decent but if I had the money I would have gone Bilistines (SP).
Also the reason I didn't use boots is because I have heard the chemicals used on the road in Colorado get stuck, build up, and dissolve the seals on the shocks. Has anyone else heard this?
I hope this helps people thinking about changing their own shocks.
Tools needed:
-Metric socket set
-PB Blaster/WD 40
-Breaker bar
Optional tools
Front:
Rear:
Fronts:
And the Rears:
Front:
Rear:
Before:
After:
06-01-2021 01:51 PM
tpd143
07-07-2015 09:06 AM
Steezy96yota
07-06-2015 10:00 AM
