Old 02-09-2016, 10:52 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Problems by Symptom
Print Wikipost
22re turns over but won't start
Old 07-22-2010 | 01:21 PM
jdmhg's Avatar
I recently got a 93 standard cab with a 22re with 154k on it. I have never had a problem with the truck starting, but when the truck was warmed up and I started it, it would seem to have a mis and idle very low...
This morning I go to start my truck and it just turns over and won't start up. I have done a little research and the only thing I have come up with is my timing chain is shot I am going to go check to see if I am getting fuel to the fuel rail and spark but from the mis and low idle when it was warmed up I am think my timing chain slipped or something.
Old 07-22-2010 | 01:59 PM
jdmhg's Avatar
Just went a pulled one of the spark plugs and I wasn't seeing any spark when I turned it over. So should I pull the distributer cap off and see if it broke or corroded?
I am very new to toyota and working on cars in general so this is all new to me.
Old 07-22-2010 | 02:03 PM
xxxtreme22r's Avatar
did you ground the spark plug to something when you tested it outside of the engine? If not you have to. Just holding it in the air isn't gonna fire it.
Old 07-22-2010 | 02:07 PM
one of the best and cheapest testing tools for ignition problems. Good thing to have is this:
http://www.autozone.com/autozone/cat...roductId=10257
Old 07-22-2010 | 05:53 PM
thook's Avatar
Uh.....if it were the timing chain, the symptoms would be qualitatively different. You'd get no compression and the motor would turn slowly as the valves are interfering with cylinder (correction....piston) movement. I doubt you're having this problem.
Could be that your having problems with the cold start system or the idle air valve is not functioning. My guess is the cold start system. Locate the sensors on the front of the motor. There's two.....one green and one brown. The brown one is the timing switch for the cold start. If it goes bad, it won't ground signaling the cold start injector to pulse fuel on start up. So, pull the connector off, run a wire from the ground side (forget which side that is, but there's only two, so only one will work) and to the battery. Make sure the connection is solid. Then, try to fire the truck up. If it still won't start, keep the ground wire connected, pull the cold start injector from the upper air intake manifold (plenum) and see if the injector is pulsing fuel. If not, then the wiring is bad somewhere or the injector has burned out.
Start there and post back. If you don't post back, you will be severly harrassed by the gentleman above. He's gnarly. Don't tempt him.
The following users liked this post:
SAIPAN670 (09-03-2021)
Old 07-22-2010 | 06:29 PM
jdmhg's Avatar
You are a good man thook I get off work in a couple hours and I'll go
check it out and give you a update
Old 07-22-2010 | 08:18 PM
thook's Avatar
Aw shucks. Where's my hanky? <<<sniffle, sniffle>>>
Okay, then. I'll check back.
Old 07-22-2010 | 09:08 PM
jdmhg's Avatar
Ha getting good advices these days is tough..
Well I grounded the spark plug to the exhaust manifold and didn't get spark, what would cause me not the get any spark?
Also what hose do I pull from the fuelrail to see if I am getting fuel?
After I check those i'll get some wire and check those sensors.
Old 07-24-2010 | 05:56 PM
jdmhg's Avatar
Well I feel alittle stupid.. Took a look at my fuse box and my efi fuse was burnt, put a new one in a she started right up
Old 07-24-2010 | 08:31 PM
thook's Avatar
Oh! Yeah, that would certainly be a problem....haha. Sorry I didn't reply sooner. I kinda have my hands in several threads right now........and usually do.
Nice that it was a simple fix! And, you're welcome fo the advice.
Old 07-24-2010 | 08:48 PM
iamsuperbleeder's Avatar
lol, dang I'm too late...
I read the title, and the first thing that ran threw my head was "15amp EFI fuse..."
Old 07-24-2010 | 09:12 PM
thook's Avatar
Did it hurt? Last time I had plastic and metal in my ear, I had to flush it good with syringe and salt water. You might try that. Hopefully it hasn't lodged in your brain.....
Old 07-24-2010 | 11:01 PM
I'll admit, you had me confused for a second; I actually had to think about that, lol
Old 07-25-2010 | 10:00 AM
thook's Avatar
Thinking requires an 80amp fuse. Consider upgrading...hahaha!
Old 07-25-2010 | 10:07 AM
ChefYota4x4's Avatar
Hahaha. Funny, guys.
That reminds me, I can't find my spare EFI fuse that I ALWAYS take with me in my rig. Especially on long trips... Picking one up ASAP.
Glad to hear your back on the road, JD!
Old 07-25-2010 | 10:42 AM
Lysmachia's Avatar
God I wish that was my problem with Tippy. We just did the timing chain and somewhere along the way the cams aren't aligned with the chain and distributor. Though I will go check that fuse now!
Old 07-25-2010 | 10:45 AM
thook's Avatar
I thought Tippy had a V6???
Old 07-25-2010 | 11:37 AM
tbland86's Avatar
kinda having the same problem. Cranks but no start. Got spark and fuel. I did the fuel pump test and it truns on. I can hear a hiss next to the fuel rail that normal? Don't see any gas leaking or vapors. Will try those cold start just someone said. Fuses and relays test good battery good. New plugs. Grabbing new cap today. Any other ideas? 86 22re efi pickup was in big puddle. Changed oil as well.
Old 07-25-2010 | 11:43 AM
thook's Avatar
You did the fuel pump test, but will it not run then, either?
Hiss next to the fuel rail? Is it actually coming from the fuel rail? Which area near the fuel rail is it coming from? A more specific location would help.
Old 07-25-2010 | 11:54 AM
tbland86's Avatar
yeah doesn't start with pump jumped. Sounds like injector 3 or right around there.
Quick Reply: 22re turns over but won't start
