22re turbo motor wont run
Ok im looking at a 90's model yota an has a factory turbo set up put on it an will start an die start an die but if you use gas Or starting fluid it will run the guy said he checked everthing an still no luck does it have to have a differnt computer fpr it to run with the turbo
Has it ever run since this engine has been swapped in ??
Then it might be a bunch of parts cobbled together .
Yes you need the ECU and like any other swap the wiring harnesses to merge.
Sounds like you have your work cut out if this was not done.
You will need the EWD of vehicle you have plus the one for the vehicle the engine came from if it was a complete engine.
If you want it to look good if not I am sure given enough time you can build your own harness.
MMA_Alex
25
04-18-2017 05:07 AM
