22re strange top end noise
Old 02-29-2016 | 11:31 PM
frankenfab's Avatar
Alright so... I had the standard stock exhaust manifold to downpipe leak.
Replaced with LCE header then did valve adjustment... Now there is an apparent sound in the top end that's super weird/haven't heard before on a 22r or RE.
I'm not sure it was not there before, may not have been audible.
Basically it sounds almost like a plastic oil can cap bouncing around in the valve cover.
It goes away once warmed up well.
Thoughts>>>???
The motor only has about 18k. Prior owner did the swap and as I have gone through other things have found A LOT of loose bolts and "havent swapped a motor before".
Old 02-29-2016 | 11:32 PM
frankenfab's Avatar
** seems to be around the rear exhaust valve area
Old 03-01-2016 | 01:17 AM
Terrys87's Avatar
Staff
I have not had an LCW header before but on other headers I have dealt with, it sounds like a weed whacker hitting the exhaust pipe. Never know what previous owners have done. I just go thru everything starting my way at the front and work to the back.
Old Red 94
01-03-2016 06:19 AM
Brandon H.
12-31-2015 07:27 PM
Johnsoline
12-31-2015 03:34 PM
MAINETOY
12-15-2015 02:50 PM
victor_26
12-14-2015 10:40 AM
Quick Reply: 22re strange top end noise
