22re and SAS?
22re and SAS?
92 runner, 22re(new), manual trans, basically stock.
here is the idea, I want to do a sas and a lift. I was thinking about ordering the sas kit and the rear leaf kit from sky-manufacturing. I came across a 85 toyota (or that is what i was told) front axle(wondering if this would work). also what kind of gear ratio should I use if I want to get a 6'' lift and 33''-35''. so far I have done all the work to it myself. this SAS idea is all new to me, I know very little about axle rebuilds and gear ratio.
so the basic questions, is a 22re strong enough for a solid front axle?
what is a recommended gear ratio for over-sized (33"-35") tires?
will the 85 toyota front axle work?
22RE will be fine if in good shape.
Any solid front axle from mini truck will work, 81-85.
33" tires will be too small. Minimum 35" tires and 5.29s
Flying91
45
04-11-2024 04:39 PM
Backcountry411
07-24-2015 08:06 AM
