22RE Head gasket failure due to rust. Learn from my mistake
I talked to a trusted radiator shop (Kirks Radiator in El Cajon Ca, they make custom radiators) he said all copper radiators are pretty much junk because of the low-lead solder used now. He said the best thing to do is get the aluminum core w/plastic tank type for $160, or he could build a better quality custom copper for $300. I hesitated on the aluminum/plastic type, but after seeing my copper one fail so early I went ahead and bought the aluminum one,
Random question. In your first pics you have a wire on the right side not connected anywhere.. i have the same one i think.. not connected anywhere.. truck came like that
Looks like its coming out of the same loom as alt. Wires..
wheres it go? Ground for something?
I recommend bolting it on so you don't have any issues. My brothers truck had that ground burn up cause it was not properly grounded and it caused all of the wiring and fuse box in the engine bay to have to be replaced.
Save yourself the hassle and bolt it in.
22re ground wire locations - the guide!!!
https://www.yotatech.com/forums/f116...-guide-194413/
Clean both the connector and the area it's getting bolted to with a wire brush or some #0000 steel wool, then smear some dielectric grease on it to help keep corrosion away.
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
