22re engine hunts
Idle is to high. Once your idle-E2 contact is closed on the TPS and the engine is up to temp your idle can not go above about 1100 or it will start doing that. This can be caused by a vacuum leak or improper idle screw setting.
Kent2,
As mentioned about idle above.
I had similar problem when AC is on and I stop at ramp from freeway speed. Got fixed when I adjusted idle to spec.
steve miller
10-10-2015 01:40 AM
