22re engine feels like no power!! HELP!!
I thought I had a bad knock sensor, swapped it out all was well. Same thing happened again no power above 2k or so. Changed it again, ran for a day. After a few days of I cut the harness back a bit and found a bad connection to the knock sensor, fixed that and all is well. Check the wiring to the sensor as well, never know what kind of a hack had that thing before you.
yeah, ill definately check the wires. the guy who i bought the runner from swapped in a 22r from a 1984 pickup and he put the stock efi on it. when i redid the top end, i had a lot of fun finding the correct parts because the 4runner originally came with a 1990 22re, and the pre-84 22r engine is totally different from the 85 and up 22r's.
when you set your timing did you use a jumper wire ..to turn off the timing advance or if you have older style bypass vacuum advance...Sounds to me your probably 5 deg retarded on the 22re
#26
man, i'm in the similar boat...except i have a completely new engine and head and rv cam from engine builder. i just don't have ANY power in fourth and fifth. it's like i hit a wall at 60-65 with stock gears and 245's!! if i find out anything i'll let you know. and i'll be watching the thread. i think i know what everybody's gonna say though...vacuum lines and all that. i'm kind of torn between afm and the computer. i think i'm goin to the mech before i start just buyin parts and slappin em on. just don't know if i'll just break even or not. sorry i'm not much more help but i'll let you know what i find.
#27
you can hardly compare your truck to his, yours is gutless because of stock gearing and 35's, get some 5.29's and it will be pretty quick. he should have lots more power than what he does, i have 32's and stock gears and i wouldnt say its gutless at all itll take medium sized hills at 60 in 4th gear with little to no slowing down
#28
#29
i actually put in a brand new motor and yes i always use the jumper when shooting the timing. im still have the lag problem....when i go full throttle in second or third, it hesitates, feels like its bogging down, and then it gets better. tested the tps and everything is fine.
maybe something to do with the ecu or injectors?? or something electrical??
#30
I'm really curious to see if u have solved this problem? I just did head gasket and tons of other new parts while I was there and it will rev fine in neutral but I can't climb over 3500 rpm in gear any gear... Now I didn't use the jumper to set the timing but when I tried the truck wouldn't start
06-01-2021 01:51 PM
Jnkml
07-06-2015 01:20 PM
