22RE dies out. Need help!!
95 toy 22re start then dies problem..
OK thats the direction Ill go, im gonna start with the relay switch cause i bet its cheaper, if that doesnt resolve it ill pull the afm/maf and run my ohms tests, still trying to find that link that indicates how to do that afm test though. You guys have been a great help, will post my results.
#27
Replaced the oc relay, 19$, no effect. Pulled the afm ran ohms test and all connection passed except for the E1 Fc, this is the actual fuel pump connection so.... I soldered this connection so its constantly sending the relay the signal to actuate the fuel pump, runs like a champ. This I know is a verrry temporary fix until I can afford to replace the 300$ afm.. Im fairly certain this hard connection wont cause damage however it will flood out the pistons if key is left on, I think.
