22re Dies in gear
yeah, i guess i should re check it and make sure the pipe has none.
I did test the maf with a voltmeter and i made sure the door was free moving.
Thanks
Thanks
#27
check your MAF again
Check your air flow meter in the maf. Pins E1 and Fc act to switch the fuel pump on after you release the key. the resistance ='s infinity if therer is no air flow, ='s 0 ohms if there is air flow. Maybe this is why the fuel pump turns off when you release the key. There's a good discussion about this subject at the toyota 4runner and pickup cheap tricks page. Me
Never understimate the power of duh!!!!!
