22re cylinder head replacement/timing chain adjuster help
I replaced my cylinder head on my 22re...I forgot to put a wedge down into the timing chain tensioner to keep it from coming out...well now I can not put the cam gear back on. Is there any way to release chain tension without removing the timing chain cover so I could put the cam back on ?
It has been a few years
So the old tired brain might not recall correct
I never used anything to hold the chain tensionor
Put the bottom all together set the head on then put the cam gear on
Someone with fresh memories might have a better idea.
First I heard about this wedge idea
I was able to stick a long rod down in there and push the adjuster in, then the cam went on without any problems.
https://www.yotatech.com/forums/f116...t-22re-159401/
millennium falcon
03-19-2017 06:42 AM
d-wood
03-08-2016 08:40 PM
