22RE Cold Start Injector Timing Switch Bypass?
Old 08-26-2013 | 08:27 AM
scope103's Avatar
Originally Posted by NHEngineer
I'm 70 years old pretty much a victim of emission control stuff.
Oh, you kids and your hot rods!
That would indicate to me to be 'effed' up timing ...
Ignition timing is the first thing I would check. Do you have a timing light? They're only a sawbuck ($20 for you youngsters).
The following users liked this post:
jjswenn (03-27-2021)
Old 08-27-2013 | 04:38 AM
NHEngineer's Avatar
Originally Posted by scope103
Oh, you kids and your hot rods! Ignition timing is the first thing I would check. Do you have a timing light? They're only a sawbuck ($20 for you youngsters).
I have one somewhere but how can it be timing? It runs slick once it's warmed up. Just like a newly rebuilt engine. Oh, wait. It is a newly rebuilt engine.
Old 10-13-2013 | 10:44 AM
68prostreet's Avatar
Is there a fuse that controls the cold start injector timer?
Old 10-13-2013 | 02:26 PM
scope103's Avatar
AM1 (40amp).
It's on the same power as the starter; if the starter turns, power is going to the CSI Timer.
Old 10-14-2013 | 05:31 AM
  #25
NHEngineer's Avatar
All of my problems mentioned previously were due to an 'effed' up distributor pulse sender. $75 and I'm back to running great again. Thanks for everyone's input.
Old 11-01-2013 | 08:27 PM
  #26
Determined that my issue was not the cold start injector or timer....Not sure what it is but I do know that if I do the key on(not start) 4 or 5 times....then try and start it...it fires right off even in cold weather.
What I have seen on some other threads that a faulty fuel pump can cause this issue. I havent tested the pressure to the rail yet but I do know or proven that its not the cold start timer or injector.
Rick
Old 11-02-2013 | 07:27 AM
  #27
NHEngineer's Avatar
Rick, could be the ICM. That was part of my problem. Sometimes I could only start the engine by rolling it with the clutch in and then letting it out. I replaced the ICM and that particular problem went away.
Old 12-23-2013 | 08:48 PM
  #28
hybridspecies's Avatar
All of my problems mentioned previously were due to an 'effed' up distributor pulse sender. $75 and I back to running great again. Thanks for everyone's input.
Forgive my ignorance, but what exactly is a distributor pulse sender? It's not the ignitor by any chance is it?
Old 12-24-2013 | 07:34 AM
  #29
NHEngineer's Avatar
I, for one will, most assuredly forgive your ignorance.
serenity03k64
06-27-2015 07:59 AM
jmc88runner
06-18-2015 03:39 PM
Quick Reply: 22RE Cold Start Injector Timing Switch Bypass?
