22R Timing Question
22R Timing Question
I have an 87 4x4 with a freshly rebuilt 22R. I am running a Weber 34 DGEC and a header. I have the timing set per the setting on the sticker under the hood, 0 with vac lines plugged from the dist, and it is dead on. My question is-should I advance or retard the timing a little based on my setup? It doesn't feel like it has the "snap" that it should. Anybody have any experience with this? Thanks
I'M HAVIN THE SAME PROBLEM! FRESH REBLD. 22R. 32/36WEB. Lc.HEADER. 8MM WIRES. ELCT;FAN & FULEPUMP W/REG... NO SMOG. CLEAN&BASIC. RUNS REAL ROUGH! TILL BOUT 3g's THEN KINDA SMOTHS OUT. WHEN I SHUT HER DOWN SHE BACKFIRES. I'VE DIALED HER TO SPECK'S COULD USE SOME HELP ALSO
Avenged
07-09-2015 07:55 AM
