22r igniter wiring
22r igniter wiring
This is the wiring for the 22r igniter. Does this look correct? I do not have the harnesses so I’m trying to figure it out. The one loose wire I know is for the tachometer. I'm not sure if I have the circled two correct or not.
Edit: So I'm pretty certain in this photo I have these two wires opposite of how they should be. The black-red wire (12v on) should go to the light brown wire. I've swapped it to what I believe is the correct way but I still cannot get the truck to start. Any chance I burned something out by trying to start the truck with the wires swapped?
crazydaydayftp
08-30-2011 05:04 AM
