22r cuts out when accelerating
86 pickup 22r cuts out when accelerating
Been replacing little thing here and there try to figure this problem out. I have replaced the cap and rotor, ignition coil, spark plugs, mechanical fuel pump, fuel filter, fuel tank, fuel tank suction assembly, intake manifold gasket, and rebuilt the carburetor. I have adjusted the timing as well. But I am still get the same issue. My next step might be replacing the distributor vacuum advance but I don't want to spend $200 on a new one if I dont have to. When I try to accelerate it seams like the motor completely shuts off until I release the pedal. Its almost like it is not firing at all when it does that. Any help would be appreciated. Thanks
