203HP 22re
Old 07-15-2008, 05:16 AM
4runnerguy's Avatar
ya true. but the motor was used when he bout it but he put a bunch of parts from trd and ported the heads, and intake. he rebuilt the entire motor and opened the cylinders a bit
Old 07-15-2008, 09:27 AM
hosh's Avatar
The black top red line is 9000 rpm and it can happily stay there all day. I think factory silver top is about 8000-8500 rpm but don't remember.
Old 07-15-2008, 02:25 PM
dcg9381's Avatar
To compare, find an 8-valve long stroke motor.... Not fair to compare with a more modern multi valve/cam motor...
Ask for a dyno run out of that shop, but don't discount the HP added by green paint.
Old 07-16-2008, 05:30 AM
DudeBud's Avatar
who wants to bet that their dyno sheets are from desktop dyno see that before on ebay
Old 07-16-2008, 06:19 AM
  #25
88T4R's Avatar
91toyota I wouldn't even chance it with this guy, I have seen I don't know how many people on craigslist fighting with this guy because they had problems with his motors and some said that when they tore them down to find the problem the motor hadn't even been rebuilt just cleaned up and put back together. If it had only been one person I would say maybe his motors our ok, but it has been quite a few different people complaining.
Old 07-16-2008, 07:20 AM
  #26
91Toyota's Avatar
Thanks! I'm actually rebuilding mine myself anyway...just wanted to look at all my options...and if it WAS true...that would be quite impressive!
Old 07-22-2008, 09:31 PM
  #27
aviatork's Avatar
DON'T DO IT!!!. He is a crook. Horrible products that he does not stand by obviousely.
Old 07-23-2008, 10:58 AM
  #28
Targetnut's Avatar
Not very likely
It's conceivable to get that power from one of these engines but your talking some serious port work and pretty high compression. As well as rpm in the 7000-7500 range. I'm thinking it would cost a lot more than they are selling them for.
Besides the engine, the engine management system would have to be upgraded
Maybe they figure the pretty paint increases volumetric efficiency
Old 07-23-2008, 12:51 PM
  #29
abecedarian's Avatar
well we all know that green paint, due to the shorter wavelength of the light reflected by it, produces less obstruction and turbulence to air passing around it than what is caused by orange, or even worse- red paint. That's why Ford uses blue- even shorter wavelength than green. The fastest engines don't use purple or indigo though, even though purple and indigo are even shorter wavelengths than blue... black is the preferred color for the fastest engines since black means there is no light reflected and consequently no turbulence and therefore produce the most power.
Old 07-25-2008, 10:38 AM
  #30
axekick's Avatar
I'm going to paint my engine red and take off my hood. Then when I'm going down the highway and the engine turns blue I know I'm going too fast.
Old 07-25-2008, 08:53 PM
  #31
Targetnut's Avatar
Hey!... Go easy on the orange, I can tell you for certain Orange is rather fast.
It's like those Turbonator/Tornado thingies (technical terms) More turbulence=fast,,,,,REAL FAST
Old 07-25-2008, 09:57 PM
  #32
algranger's Avatar
imo if you push a 20r 22r or 22re that hard, its not gonna last as long or beas reliable as your stock motor
Old 07-26-2008, 12:01 AM
  #33
EWAYota's Avatar
Soon to be added to sig!
JNapolitano
11-14-2019 07:46 PM
Stull
08-28-2015 05:53 AM
ia02
08-20-2015 11:04 AM
PlayAwhile
07-20-2015 11:36 AM
Quick Reply: 203HP 22re
