1st gen OME lift?
Ike, TC, Flygstein, et al, will back me up on this:
If you you're looking to improve offroad capability, get a locker (or two). It will do more for you than a bracket lift to enhance trail abilities.
If you want the aesthetics of a lift, lockers are useless.
Check the locker FAQ:
https://www.yotatech.com/forums/f31/locker-faq-43572/
HTH
Edit: BTW, I'm considering going with most of the Slee/OME setup for the ride. My rear is saggy if I don't have some air in the AirLift RideControl bags. Was debating the Dakar vs Alcan leaves. Have the SAW 25mm T-bars, but i think they're too stiff for a 4 cyl. Have them completely relaxed at the moment, but also don't have the heavy skid & belly pan on either. Already have the steering dampener & BJ spacers.
HTH
I just purchased a set of Dakar springs, I had initally thought I got the wrong springs, but the CS019R is the medium spring for the IFS truck and runners? and gives 1.75" lift. The CS009R was what I thought I wanted is the HD spring spec'd for the 84-85 solid axle trucks.....
http://www.arbusa.com/uploads/PDF/ac...ota4Runner.pdf
Can anyone tell me where to buy BJ spacers?
vanion2
07-29-2015 06:17 PM
MTLroadierunner
07-20-2015 03:07 PM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
