1994 Toyota pick up 2.4 22re w55.
Im currently replacing my clutch set, flywheel, transmission seals, rear main seal and clutch pivot ball and for. However, when i was pressure washing the inside of the bell housing to remove the thick gunk. One side of the fork boot was bent in wards and wont go back. Is this something I can glue back into place or do i need a new one. It isn't stretch and has no cracks just bent inwards like a V.
The boot is 26 years old. If it's bent and won't go back in place, the rubber is likely stiff and ready to crack some more, so best to get a new one. Toyota part # 31126-20060. $15 to $20 at almost any dealer or on the web.
The following 2 users liked this post by 13Swords:
2ToyGuy (02-10-2021),
GucciManeIn2006 (02-11-2021)
YT Community Team
You could try boiling a pot of water, turning the heat off, then dropping the boot in for 1-2 minutes. Good chance it'll regain it's original shape. If not, the boot is easily ordered.
Good advice from Jimkola
after the hot bath, coat the boot with dielectric grease it will restore its pliability, if its not too far gone.
Give us a report on how it goes...
Just a small note: Vaseline works very well, too. I use it on long-lived rubber items. O-rings, small, seldom replaced hoses, rubber door and window seals, and so forth. A thin coating does the trick. On the hoses, a thin coat inside, where they go on the hose barbs not only preserves the hoses nicely, but helps them slip on more easily. Keeps them from "sticking" to the hose barbs, too, as hoses are prone to doing.
I use the Vaseline on my rubber door seals every fall. Makes them soft and pliable, AND keeps them from freezing to the metal of the door frame when it gets really cold. A problem we had the first year we moved to Oregon. Never again.
I use Vaseline on my water filter o-rings too. Makes them last forever. Kinda nice.
Have fun!
Pat☺
Have fun!
Pat☺
lparkerlpn
08-18-2016 12:43 AM
s2_4Runner
08-13-2012 08:28 PM
