1994 Toyota p/u 3.0 is idling rough and has a miss
A compression tester measures how much compression/pressure is generated from a compression stroke.
A Leak Down Test measures how much compression/pressure is lost at the peak of the compression stroke.
They are two different tests, performed two different ways, using two different pieces of equipment.
It sounds like TNRabbit has a combo unit. I wish I had one to save on space in my tool box.
Post up your compression numbers.
Remember...leaving the compression tester attached for 3-5 minutes is a waste of time and tells you nothing about your engine. It only verifies that your compression tester can hold pressure.
#26
We're going to need that last cylinder to form any conclusion. Those numbers are low, but all uniform. They're probably low if the engine was cold when you performed compression test. If that last cylinder has similar pressure, we need to start looking elsewhere. Please post up pics of the tips of your spark plugs. Clues to the puzzle...
#29
Host them on photobucket.com and copy the code below the picture labeled img. Paste that in your post on yotatech and your good to go.
Definitely need to get that last compression number. That may be your dead one. That's usually how it works for me anyway haha
#31
Update..........all cylinders are good. The previous owner had the rotor cap turned up I think to gain more power. I have turned it back and have seemed to take out the idle problem. I replaced the fuel filter and added sea foam to the tank last night. It seems sluggish, I will run this sea foam through this tank and see how that does.
Peteyg39@hotmail.com
06-26-2015 08:15 AM
Crazy_Guy97
12
06-24-2015 04:02 PM
