1994 pickup front grill/corner light plastic inserts
I'm looking for any help with part numbers for the plastic inserts (bushings) that attach to the sides of the front plastic grill that hold the 2 "prongs" of the corner lights. I do not know what they are called or the part numbers for these. Any help would be much appreciated.
THANKS!
THANKS!
Start with the link below. You can change year/model/frame code/char by clicking on tabs. Click on 5 digit part #s to get the 10 digit part # to order from Toyota.
https://www.japan-parts.eu/toyota/us...clearance-lamp
The following users liked this post:
Gorgonio (09-29-2024)
YT Community Team
I grabbed a random 1994 model number to look up the part, but this should work.
Toyota calls the corner lights "clearance lights" if you go to epc-data.com and look up parts
The link I posted is the same corner lamp/clearance lights that you located. The link can also be used to find part #s by clicking on the 5 digit # to find the 10 digit part number.
neilcut94yota
08-03-2016 08:28 AM
