1994 p/u third brake light
Hey, I'm new here so be nice to me. Actually I've been reading the tech posts here for awhile now, but finally decided to join.
Here's my issue. I bought a 1994 four wheel drive truck in January. It's been in my shop since then, just fixing all the little things that need to be done to a truck with 300k miles on it. I was checking all the lights today and found the third brake light isn't working. Tracing the wires back I found them in the left kick panel near the fuse block. They are white/black and green/white and end in a white plug. There doesn't seem to be anyplace to connect the plug to. Looking closely at the fuse block I found some writing on it that makes me believe the fuse block has been replaced, maybe from an older model that didn't have the third brake light. I need to make the light work to avoid tickets and being rear-ended!
If anyone can tell me what's missing, or where to connect the wires I'd appreciate it.
Welcome to YotaTech!
W-B is ground, and G-W is switched battery for all the brake ("Stop") lights. The connector you're looking for is IJ1:
If you don't have that connector on your harness, all you need to do is get W-B to ground somewhere, and G-W to the other G-W wires. The GW wires come from the stop light switch, and then go through a splice on the way to the back. Just pick it up any place convenient.
greyheadedguy
06-07-2016 12:16 AM
jtm994
07-27-2005 07:41 AM
