1993 Toyota Pickup Headlight Issues
For starters, I'm not a tech, and I am not much of a car dude, but I've been working to change that since it's a lot cheaper to fix your vehicles then to take them to someone else.
Anyways, I've got a strange issue with the headlights my 1993 Toyota Pickup. It is the 22RE model. Here's the deal, my passenger side headlight went out ( or so I had thought), though when I switched the lights to hi-beams, the passenger side light turns on the and the driver's side headlight goes out. When the lights are switched to regular/low-beam, the driver's side headlight turns on.
From the bit of research I've done, it sounds like it could be a bad headlight relay. I checked the fuses and all of them are fine, though I was hesitant to check them at first, since the each of the lights do turn on, just not together. Am I correct in this guess or are there some other things I should check out to further diagnose the issue?
I believe 93 2Re headlight wiring is same a first-gen Runner 22RE wiring. Please look at schematic of your own truck.
Headlight relay will NOT cause your symptoms (see schematic below). Mad relay will affect both sides the same way.
This problem sounds like either:
1) One fuse busted or wiring from relay, through ONE fuse to that side headlight, OR
2) One busted filament.
Current leaking through remaining filament causes odd behavior.
I suggest you :
1) Double check your fuses . Resistance measurements not just visual.
2) Do resistance measurements on connector pins of bulbs. Pin 2 to Pin 3 should read low. Pin 3 to pin 1 should also read low. Both close to 1 ohm.
3) Take voltage readings at each pair of bulb connector. Look at schematic for color code.
High Beam: Pin 3 to pin 2 read 12V
Low Beam: Pin 3 to pin 1 read 12V
Then we'll go from there.
I suggest you :
Therefore, it is quicker to:
1) Take resistance and voltage checks in-circuit. and
2) Thoroughly inspect AND clean wiring, connectors and fuses.
Aleeex_u
06-05-2016 06:52 PM
WTB[International]: 93 P/u fuel door lock, roll bar, hitch, chrome rear bumper
Gamble_STi
06-27-2015 07:54 PM
