1993 3.0 v6 cylinder pressure
Hey all, I would appreciate any advice; I have a 1993 toyota P/U 4x4 that recently started idling rough. It has 230,000 miles, what is the minimum cylinder pressure that I should measure? I checked them out, they were all above 160, any advice?
The manual say normal is 171 psi, minimum is 142 psi, and the maximum variation between cylinders is 14 psi. I would think above 160 with 230,000 miles is pretty good.
